01 6.0 engine harness work on 02
Old Apr 15, 2004 | 10:57 AM
benpimpin1's Avatar
Default 01 6.0 engine harness work on 02
I found a engine harness off of a 2001 6.0 C3 truck. Will this work on my 02 1500 silverado. Both are automatics, I need the engine harness so I can do my v-6 to v-8 swap, if anyone can help I would really appreciate it.
Old Apr 15, 2004 | 11:01 AM
bmbutler's Avatar
Should be exactly the same.
My '99 5.3l harness worked with my '01 6.0l motor.
Old Apr 15, 2004 | 11:02 AM
BlownChevy's Avatar
blownerator
25 Year Member
Should be good to go!
Old Apr 15, 2004 | 11:04 AM
OBXMarine's Avatar
NO!!!!! That's my harness!!!
Old Apr 15, 2004 | 11:13 AM
Default Throttle?
If I'm not mistaken 02 was the year they went to fly-by-wire throttle. ERG deleted in 03?
O.K. Now I read it again. Did 02 V-6 go to fly-by-wire throttle?
Old Apr 15, 2004 | 11:42 AM
Flyer's Avatar
03 is electronic throttle bodies, 02 is when they removed the EGR.
I think you should be fine.
Old Apr 15, 2004 | 12:00 PM
bmbutler's Avatar
EGR won't matter, you can either add it or take it away with EDIT.
My 6.0 (2001) had EGR on it, but I disconnected it and its now in the trashcan. I used a freeze plug do close the hole it left in the intake (thanks Allen).
Allen is sending me the new PCM with EGR deleted so no SES codes.
Its the electronic tb I'd be worried about.
Old Apr 15, 2004 | 02:24 PM
benpimpin1's Avatar
The motor I am swapping in is an 01 also, but I wasn't sure if anything was different because it was a C3 harness so it is awd and I wasn't sure if it had the 4l80e. Does that stuff make any difference?
Old Apr 15, 2004 | 02:43 PM
bmbutler's Avatar
If it didn't have the 4L80E originally (which I'm pretty sure it didn't), then all you have to do is order the harness from Speartech(site sponsor) for $160 like nearly the rest of us did.
Bumpers
Aug 4, 2024 09:44 PM
ARC
57
Feb 21, 2022 10:54 AM
chopperloco
Jul 10, 2016 10:45 PM
steves86ta
Jul 28, 2015 10:21 AM
Nimoryan
Jul 5, 2015 03:50 PM
