00-02 PCM swap questions
Old Feb 28, 2005 | 04:21 PM
Wilde Racing's Avatar
How do I change this text
Default 00-02 PCM swap questions
I'm doing some research before I get my STS kit (I'll be ordering it Friday). I'm a little worried about my 00 PCM so I did a search and found I needed a 02 PCM. My question is when I called my local wrecking yard; they said any 02 PCM out of an avalanche, s-10 and even a van would work. Is this true??? If so, I'm sure the tunes would be different. I also called Allen to see if he would sell me a PCM, and or do a tune for me, not so sure on the HP tuner thing.
Thank you for any input.
Old Feb 28, 2005 | 04:27 PM
Yelo's Avatar
An Avalanche or Van PCM *should* work plug-and-play....but an S-10 PCM would definitely be a no-go in terms of plug-it-in-and-go programming
Old Feb 28, 2005 | 04:33 PM
but it has to be 02 and up right?
Old Feb 28, 2005 | 04:37 PM
Yelo's Avatar
right....
The S-10 PCM could probably be programmed to work with your truck, but I'm not real sure about it
Old Feb 28, 2005 | 04:40 PM
Thumbs up nelson tune
allen & 02 pcm is all you need he the man
Old Feb 28, 2005 | 05:29 PM
JERRY2500's Avatar
14 Second Truck Club
Allen fixed me up
Old Feb 28, 2005 | 05:32 PM
Ya I still might go that route, I cant make up my mind with the HP tuner. I'll have a wide band (dyno jet) ether way.
Old Feb 28, 2005 | 05:57 PM
custom tune & a man that knows how is all you need never get it any other way = power=driveability = all in one
Old Feb 28, 2005 | 06:32 PM
In my area that means a four hour drive to the nearest dyno tuner.
XL7
May 5, 2022 01:48 PM
Bluchevypick
Aug 18, 2015 09:11 AM
USMCvet0311
Aug 1, 2015 07:45 AM
chvy=power
Jul 27, 2015 10:06 AM
GreyChevy
Jul 7, 2015 08:57 PM
