**HELP QUICK PLEASE** No spark on my new motor
Old Mar 21, 2007 | 04:51 PM
  #51
454SuperSport's Avatar
give me some more info and i'll try to give you a diagram, what year truck? what engine/trans came in it? what engine trans did you put in it? are you using the original wiring harness/computer that came in the truck?
Old Mar 21, 2007 | 04:54 PM
  #52
oh, and make sure you do a write entire when you disable the vats
Old Mar 21, 2007 | 05:51 PM
  #53
Flyer's Avatar
Pretty sure that the spark logic is in the PCM, which uses various inputs to control spark timing...
What he said!
Old Mar 21, 2007 | 05:52 PM
  #54
Flyer's Avatar
03 1500 5.3/60e
It now has an 80e and a 6.0/408.
Old Mar 21, 2007 | 06:00 PM
  #55
Flyer's Avatar
I did do a full write on the disable VATS tune.
Old Mar 21, 2007 | 06:07 PM
  #56
thunder550's Avatar
High on diesel fumes
Any codes stored in the PCM? Do you have another PCM you can try instead?
Old Mar 21, 2007 | 06:18 PM
  #57
WJ MARK's Avatar
I just remembered the Vats in my buddies Truck cut the fuel and not spark.
Old Mar 21, 2007 | 07:15 PM
  #58
ok, did some quick checking, coils 1/3/5/7 get power from INJ 1 fuse, coils 2/4/6/8 get power from INJ 2 fuse, pin D on all coil connectors is ign. power (pink wire), pin A on all coils is ground (black wire). check the coil grounds for resistance and check the fuses. the coil ground goes on the driver side of the engine on the same bolt as the negative battery cable.
Old Mar 21, 2007 | 07:20 PM
  #59
heres the diagram for the grounds on the rear of the engine
Attached Thumbnails **HELP QUICK PLEASE**  No spark on my new motor-rear-engine-grounds.gif
Old Mar 21, 2007 | 07:23 PM
  #60
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Hey Nathan,
Have you flashed in the 80E segment and wired the second VSS connector to the PCM yet?
If so, are you sure you hit the right post for the connector?
