Z71 w/ tow package, rear end
Old Aug 7, 2007 | 09:47 PM
wayland1985's Avatar
Default Z71 w/ tow package, rear end
I'm looking for a replacement for a 99 Silverado's rear end. I'm pretty sure a third member is all I need, but I'm not sure what kind of axle I have from the factory. DANA? 12 Bolt? None of the above?
Old Aug 7, 2007 | 10:00 PM
KevinF56's Avatar
10 bolt.
Old Aug 7, 2007 | 10:06 PM
gotcha... thanks bud...
Old Aug 8, 2007 | 07:47 AM
Anybody know a good replacement for it?
Old Aug 8, 2007 | 08:22 AM
KevinF56's Avatar
replacement for what? just the differential?
Old Aug 8, 2007 | 10:55 AM
Yep...
Old Aug 8, 2007 | 11:19 AM
ZZebes's Avatar
Tru-Trac
BTW Specs are
GM 10 Bolt
8.625" Ring Gear
33 Spline Axles
C-Clip
Old Aug 8, 2007 | 11:26 AM
Nick™'s Avatar
Tru-Trac or the Eaton LSD
I have the Eaton LSD, but honestly the Tru-Trac has no clutches to wear, and being that they are the same price might as well go with the Tru-Trac.
Old Aug 8, 2007 | 12:46 PM
Where can you pick one up? And this thing is pretty much drop-in?
Old Aug 8, 2007 | 01:37 PM
KevinF56's Avatar
i got my truetrac on ebay. summit racing has them as well. if you're replacing just the differential, it should drop in provided that you keep your stock shims in the exact same position. you should be able to obtain the right amount of backlash. i personally had my mechanic install it. i didn't give him any shims to install it with. i don't think he had to use any.
if you want, contact GMracer. he installed his and we were going to do mine, but i had my mechanic do it. i'm sure Nick (GMracer) might be willing to help you out with the install.
pjb1972
Sep 17, 2015 02:06 PM
TimDave217
Aug 24, 2015 04:38 PM
vipergtrdj
Aug 6, 2015 10:19 PM
shupe
Aug 5, 2015 06:45 PM
Ketis
Jul 23, 2015 12:37 PM
