Yank PT3200?
Old Jul 13, 2010 | 08:46 AM
mikeyjm1's Avatar
Default Yank PT3200?
does anybody tow with one of these? I dont expect to tow often but when I do it will be 6-7k for several hundred mile at a time. can this TC still work ok for me?
Old Jul 13, 2010 | 11:55 AM
Jeteys5.3's Avatar
if you are going to be towing, i'd say check out the TT series. However it limits you to a TT3000.
I recommend Circle D, give chris a call and he will recommend what is best for your needs.
Old Jul 13, 2010 | 12:38 PM
MPFD's Avatar
11 Second Truck Club
The Pro Truck line is a way tougher and heavier duty clutch then the TT line of Yank converters. Thats also the reason they are more expensive.
Old Jul 13, 2010 | 12:46 PM
Jeteys5.3's Avatar
whats the towing capabilites as he will be pulling a heavy load? I glanced at yanks site and didn't see anything mentioned, just saw it mentioned on the TT series.....being heavier duty i'd believe its capable but it doesn't mention it
Old Jul 13, 2010 | 03:25 PM
8.1 HD's Avatar
I run a CircleD 2600-2800 and tow with it, Chris recommended to go with it or if I didn't tow too much a 3000. After having it for awhile I do not think a 3000 would be that bad, as long as you have a big enough trans. cooler.
Old Jul 13, 2010 | 03:27 PM
454navyss's Avatar
i called them about the towing capabilities of the pt series verters a few months ago and they told me i would be ok pulling about the same weight you mentioned
Old Jul 14, 2010 | 12:38 PM
MPFD's Avatar
Originally Posted by Jeteys5.3
whats the towing capabilities as he will be pulling a heavy load? I glanced at yanks site and didn't see anything mentioned, just saw it mentioned on the TT series.....being heavier duty I'd believe its capable but it doesn't mention it
My PT3600 has the 6 bolt front cover and lock up clutch from a 4l80e converter with a hub snout designed to fit a 4l60e.
Old Jul 14, 2010 | 01:57 PM
03lowriderss's Avatar
i recently got a pt3200 and wondered why is there 6 bolt spots on the front of the verter, but the stocker only has three.?
Old Jul 15, 2010 | 10:12 PM
fredkj3's Avatar
it will work with a ls1 or a lt1
Old Jul 15, 2010 | 11:02 PM
wyatt_450's Avatar
yank 3600
