WTF Bell housing bolts!!!!
Old Dec 1, 2008 | 04:01 PM
GMCDee's Avatar
Got them all out some of them i could almost break them loose with my hand thanks again for the help gents.
Old Dec 1, 2008 | 05:53 PM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
+1 on th T-50 bit. Otherwise, those bolts will strip at the head... as you've seen.
Old Dec 2, 2008 | 04:41 PM
SnakeOiler's Avatar
why are you trying to take these bolts out? I'm a little lost on that one.
Old Dec 2, 2008 | 04:43 PM
Mangled03gmc's Avatar
Baltimore Whore
He bought a new trans, it didn't come with a bell housing...
John
Old Dec 3, 2008 | 08:28 PM
Copper&Black's Avatar
I see you got them out, but in my turbine shop when a bolt is seized up in a case, Liquid Wench Penetrating Oil around the bolt head allow to soak in, over night if possible, Heat, Allow to cool (The difference in material will expand and contact at different rates and could break the bond between the two), Heat until hot, Spray Penetrating Oil (carefully this might light the oil on fire if it is hot enough, don't think it's wise to get it that hot on the bell housing though), Strike the head of the bolt with a hammer, this will break the bond between the bolt and the case (hopefully) and should be able to back out, if it doesn't work the first time, repeat. I realize this is nearly the same as what everyone else is saying, but shocking the heated bolt that is surrounded by penetrating oil with a hammer is the best way to break it free.
fastjweb
Aug 31, 2015 09:57 AM
Abuckeye
Aug 19, 2015 06:11 PM
lycominghunter
Aug 15, 2015 12:26 PM
