Wrong flexplate??
Old Dec 21, 2011 | 10:31 AM
1FastBrick's Avatar
Custm2500's Rude Friend
Is the builder saying or seeing any thing going bad or wrong with it??? Did you have that converter Checked out at all???
I am not saying Any thing bad about getting a used converter only that it should be inspected to make sure everything Is 100% Correct before using it for your application. For example, Would you buy a used crank and just throw it in a new motor???
Also Did you look at Crankshaft end play on your motor??? Excessive thrust play could cause a similar problem.
Also might help to put a pressure gauge on the trans to make sure the fluid is flowing properly.
Hope one of these suggestions help!!! Keep us posted.
Old Dec 21, 2011 | 10:45 AM
03regcab sierra's Avatar
I got the converter cleaned and restalled on this last build. The builder said it all looked fine inside the trans. 2nd gear did have minor wear on clutches which he replaced. ill check the thrust play and get a gauge on it.
Old Dec 21, 2011 | 10:48 AM
1FastBrick's Avatar
When the Builder takes it apart did he notice any signs on the pump gears that its not engageing properly or spinning out???
Old Dec 21, 2011 | 11:02 AM
He didnt say but maybe I can see it when I pull the converter out. Im thinkin of goin back to a 6 bolt lq4 flexplate and stock converter to see if it works. then order a nice circle d once I get it back up and running.
dsbodley
Nov 14, 2015 09:46 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
carid
Oct 1, 2015 09:22 AM
g6t6o
Sep 26, 2015 10:57 AM
69z-28
Sep 21, 2015 07:31 AM
