Would like to go an inch lower.
I have the ground force 2/4 lowering kit. Any way of lowering it another inch instead of having to buy another whole kit. I have the front coils and rear leaf spring set up. I think it is part #9993. Also why is ground force lowering kits so expensive. Are they that much better than everybody else. I bought the truck with the kit already installed.
How about ride quality if I heat the coils. Will it be any different than what I have now. Back to one of my original questions concerning ground force, why are they so much more than the others?
Yours springs will get effectively stiffer if you collapse the top coil. If you plan to try this make sure to keep the ends of the spring square. Also depending on where the spring sits on the control arm, you may get more drop than the amount you collapse the coil. I think rear leaf springs cost more than a hanger/shackle drop kit.
