WOT shifting issue 4l80e
I have been having problems with WOT shifting. For some reason my truck wont shift out of 1st or 2nd under WOT. I am commanding it to **** at 43 MPh, and 4400 RPM's. It will hit the rev limiter every time at 7200 RPM's at 55 MPH. I have tried lowering the MPH and RPM with no difference. This also happens when it shifts out of 2nd. I command 74 MPH at 4600 RPM's, and it is shifting at 7200 RPM's at 92 MPH. I initially wanted it ot shift at about 66-6800, and the RPM lowering doesnt help. Any suggestions? It seems someone else on here had this problem, but I couldnt find it with a search.
i had a problem with mine doing the same thing. I would do logs and it would hit the rev limiter every time. From my logs it needed to shift at 45mph to match the rpm i wanted to shift at. I had to eventually drop my mph down to like 36 before it would even shift out right. Could you post your tune?
Here is a link to my tune. Post 40. I can get you one that is in it right now after work. It is basically the smae thing except i lowered the MPH, and RPM quite a bit without any changes.
https://www.performancetrucks.net/fo...-503495/page4/
