Will I benni any from removing the overload spring??
Have the springs out,ready to put the cal tracs on, now wandering if this will help in any way shape or form will help hooking this thing up.. Pros cons please..
Thanks John
Thanks John
Take it out. I had the chance to remove them when I was installing the caltracs and now I have to do it again. My truck was level and after the caltrac install it sits an inch or so higher in the back. I bet removing the overload will fix that.
I removed mine to level the truck and to try and get a little better squat in the rear on launch. It did both of those things but resulted in pretty severe axle wrap and wheel hop. If you have removed overloads with cal-tracs I'm guessing you will be in good shape... I'm ordering a set as soon as I get this turbo kit in line and start going to the track a little more regularly.
How much weight will you need to carry with the truck? If you pull the overload it will reduce the spring rate in the rear, I'm not sure if that's best for traction. You would ideally want to have much less rebound damping in the front shocks to help with weight transfer. I don't have any good info if it helps or hurts traction.
If your going max effort for traction remove it , with Caltracs you only need enough spring to support the vehicle. On mine I have the wimpy D100 springs with only 4 of the leafs with the overload removed. So far its gone 1.32 60 on drag radials.
Ok guys thanks for the info. I do not plan on carrying anything super heavy.. Thats my goal and to get it to hook well.. I should have these licked today. Taking my time
John
John
jtphelps289
Sep 29, 2015 12:00 PM
323steel36
Aug 25, 2015 05:11 PM
