Will the engine/tranny/transfer case come out as one piece?
Old Apr 15, 2006 | 02:37 AM
thunder550's Avatar
High on diesel fumes
Default Will the engine/tranny/transfer case come out as one piece?
....or do I have to separate them?
Old Apr 15, 2006 | 08:46 AM
litreddevil's Avatar
Banned
separate them
Old Apr 15, 2006 | 12:05 PM
thunder550's Avatar
Damn
Old Apr 15, 2006 | 12:14 PM
Quik's Avatar
5 year bitches!
i know the motor and trans came out of mine as one. it was alot easeir for me to do it this way. i dont knwo about the case. what i did was remove hood, remove rad, ac condensor and upper rad brace. after that its just pull and go.
Old Apr 15, 2006 | 12:17 PM
thunder550's Avatar
Was it tight? I think the t-case makes it a few inches longer.
Old Apr 15, 2006 | 01:55 PM
desTRUCKtive's Avatar
in your case remove them both, you can get them out as one piece, but you need to take the intake off. and then your truck is a little high so you will need a picker that will go up pretty high in order for the pan to clear the front. But for sure you will need to take the intake off.
Old Apr 15, 2006 | 03:13 PM
thunder550's Avatar
Thanks Beto - I'll drop the front end down a little and give it a shot. I'm gonna try to pull it all this week.
Old Apr 15, 2006 | 05:38 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Pull the t-case and the engine/trans will come out as one.
Old Apr 15, 2006 | 05:45 PM
99Silver6.0's Avatar
I took all the **** out at one time. I was too lazy to seperate it. Had to put a hell of an angle on it when lifting. Plus the truck had to be up off the ground for the tail shaft to clear the ground.
Old Apr 16, 2006 | 03:04 PM
Did you not take the intake off? I thought that you did. I guess you might be able to take it out as one piece with the intake on, but you have to remove the crank pulley.
