Will a Camaro 4L60 work?
Old Sep 17, 2007 | 02:20 PM
shakinlm7's Avatar
Question Will a Camaro 4L60 work?
I have been given a 4L60 core. I haven't seen it yet so I'm not sure if this will work on my truck. its out of a 97 camaro. I've tried to look it up but I'm pulling up different part numbers, I don't know if its just because the bell housing has one less bolt or what. Should this work in my truck?
Old Sep 17, 2007 | 02:22 PM
UBLUZIN03's Avatar
im pretty sure a 4l60 is a 4l60 no matter what its in...so yes it will work..
Old Sep 17, 2007 | 03:13 PM
Bill Reid's Avatar
Tail housing would need to be changed... not sure about other stuff like gear shift indication / neutral safety module or vehicle speed sensor. Hopefully Vince from FLT will chime and clarify
Bill
Old Sep 17, 2007 | 06:03 PM
adam1803's Avatar
Im pretty sure its a 97 model Michael.
Old Sep 17, 2007 | 06:57 PM
Quik's Avatar
5 year bitches!
fbody 60 is same....only difference is the shift linkage arm. it will need to be changed out to work with the trucks black box besides that its the same. the tail housing can be changed or left alone. doesnt matter either or
Old Sep 17, 2007 | 08:42 PM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
Dude... that 4L60 is NOT... I repeat... NOT going to bolt as a plug & play unit.
The F-body version is DIFFERENT from the truck version. The input shaft/drum, pump (even part #s are different), and bellhousing are different. Everything else is the same. See the pic below. F-body shaft on the one to the left, truck version on the right.
If you don't believe me, wait for the pros to chime in, but that's the truth. You can change those parts to make 'em work, but don't think it'll bolt up as-is and run.
Old Sep 17, 2007 | 09:45 PM
shakinlm7's Avatar
Thanks for the input so far guys, and I believe you 1bad haha!
Old Sep 17, 2007 | 10:28 PM
adam1803's Avatar
So couldn't you just use an fbody converter and not have to change out the input shaft?
Old Sep 18, 2007 | 06:38 AM
95ImpSS's Avatar
Now that, dear sir, is an idea. Though I'm not 100% sure if you need to change out the flexplate or anything. That would seem like it would indeed be easier if you didn't want tear down the trans, but I do not know the answer to that one.
Old Sep 18, 2007 | 10:08 AM
Quik's Avatar
5 year bitches!
then i guess i didnt have a fbody trans in the truck for a short period while mine was down?
how is the bell different? how is the input different? when they use the same converters are the cars? i ran a car converter for 8k in mileshad no issues. also had a TB stall installed ina Fbody
unless you are referrign to a early year truck trans then yea, but my 02 trans was teh same!!!!!!!!!!!!! i speak from experience not somethign you read off the net
