Will a Camaro 4L60 work?
Old Sep 18, 2007 | 10:09 AM
Quik's Avatar
5 year bitches!
Originally Posted by adam1803
So couldn't you just use an fbody converter and not have to change out the input shaft?
dont believe eveything you read on the net......i had a fbody converter for many miles and now a member on here has it
Old Sep 18, 2007 | 10:10 AM
Quik's Avatar
5 year bitches!
Originally Posted by shakinlm7
Thanks for the input so far guys, and I believe you 1bad haha!
dont believe everything you read....alot of misinformed informantion out there
Old Sep 18, 2007 | 10:23 AM
shakinlm7's Avatar
Hey 1Bad do you know what year Fbody and truck trans are in those pictures you posted. and what about you Quick what year trans and converter where you working with? I'm studying for a test today but hopefully I can pick up the trans from adam within the next couple days to see what I'm actually working with....
Old Sep 18, 2007 | 10:29 AM
Quik's Avatar
5 year bitches!
hey might be thinking the 98/ LT1 60 trans......i had a 00 fbody trans i ran short time. the converter was a PI converter for the LS1s
i know for the pinks car it used the old style 60 which used a 700r4 style converter. which was a 98 based trans
Old Sep 18, 2007 | 10:58 AM
kbracing96's Avatar
There is not a difference in the fbody vs truck tranys, it's a difference in the years. The one on the left is an older one and the right is a newer one. I don't know where the switching point is, but that is the diff.
Old Sep 18, 2007 | 12:29 PM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
Quik is accurate. It does depend on year. I don't know when that year difference ended though. When did the truck & fbody models become the same? If shakin (or ANYONE else) doesn't know that, you can't just assume. Hence, the reason boards like this exist. My bad for not mentioning the uncertainty of year differences. I can't remember everything.
As long as the shaft on the trans your getting looks like the shaft on the right of the pic I posted (from MY first build), odds are you have the correct pump, input shaft/drum, and bellhousing. I'd verify the pump casting to be sure. I've bought a trans from someone before (without seeing it in person), and was told it would work (but I got what you see in the pic I posted). Bottom line is, VERIFY what your getting is what you're supposed to be getting.
Good luck!
Old Sep 18, 2007 | 12:41 PM
shakinlm7's Avatar
Thats what I was thinking after what quick and 1 bad said. So if thats the case I need to find out if the 97 TC will bolt up to a LM7 flexplate or if I can find a 97 flywheel that will bolt up to my motor.
Old Sep 18, 2007 | 03:33 PM
Quik's Avatar
5 year bitches!
haha the LM7 flywheel wont work cause they never had manuals. lol the flexplate is what you are thinking of
Old Sep 18, 2007 | 03:46 PM
shakinlm7's Avatar
I have no clue what your talking about lol
Old Sep 18, 2007 | 05:32 PM
95ImpSS's Avatar
I'll see about taking a pic shortly. Hang tight...
