Will a 700r4 work for me
Old Dec 20, 2008 | 09:22 AM
ALL85's Avatar
Registered User
Default Will a 700r4 work for me
can I use a 700r4 on a 6.0 motor with a carb?
Old Dec 20, 2008 | 09:35 AM
Wilde Racing's Avatar
How do I change this text
Sure, but there are better options....
Old Dec 20, 2008 | 03:56 PM
ALL85's Avatar
Registered User
what are my options and costs? I'm looking to run 11.50's on motor (no cage) in a 95 or so 1/2 ton 2wd short box on a dragradial.I've ran small blocks and big blocks 454&502 but now I want to try a 6.0 on carb since I'm old school and alot better tuning a carb than I am with a computer.
Old Dec 20, 2008 | 04:09 PM
Are you going to run a carb on the 6.0?
Old Dec 20, 2008 | 04:46 PM
ALL85's Avatar
Registered User
yes that is my plan
Old Dec 21, 2008 | 03:33 PM
L7 Sierra's Avatar
Yes you can just make sure your tv cable is properly adjusted as this will ruin a trans fast. Theres a new valve body that removes the problem but it is a touch expensive but worth it.
Old Dec 21, 2008 | 05:13 PM
ALL85's Avatar
Registered User
can you run the newer trans without electronics if you go to a manual valve body.just trying to feel my way through this,I've ran a 700r4 with mods for 3yrs with no trouble but I'm open to suggestions.
Old Dec 21, 2008 | 10:23 PM
02silvy's Avatar
i think there is a controller for the 4L60-80's that places a throttle pos. sensor on the carb and you set the shift points. if this is going to be somethin that you dont really care for overdrive id run a TH400. i think all that it requires is a crank spacer and flexplate and d/s yoke. a buddy of mine did a TH400 swap in his WS6 and didnt have to get a new d/s but it could be diff on trucks.
Old Dec 22, 2008 | 01:17 AM
performabuilt's Avatar
LS1TECH & Trucks Sponsor
You can go full manual with the 4l60e and even have vaccume pressure control so it isnt always beating you to death
Old Dec 22, 2008 | 04:53 AM
ALL85's Avatar
Registered User
do you know what something like that would cost?I'm assuming thats what you do.Thanks
Stainless Works
Apr 10, 2016 04:34 PM
GrooveCityZ71
Aug 31, 2015 12:05 PM
Stainless Works
Aug 4, 2015 12:56 PM
atxlt
Jul 20, 2015 11:06 PM
Nimoryan
Jul 5, 2015 03:50 PM
