Wierd chattering noise????
Old Oct 29, 2006 | 01:09 PM
cadmafa's Avatar
Default Wierd chattering noise????
I got a 2000 silverado ext. cab 4x4, and everything is in super condition. Except that when I turn left and go over small bumps(like a rough road) it makes almost like a metal on metal chatter. Like....click click click??? On a really smooth road it doesn't make a sound. I can also feel that same chattering in my steering wheel...I'm guessing it might be my cv joint in the IFS system.???? Any ideas
Old Oct 29, 2006 | 03:54 PM
cadmafa's Avatar
c'mon....somebody help! lol
Old Oct 29, 2006 | 06:50 PM
Grumpy5.3's Avatar
lube your steering shaft!!!!!
Old Nov 10, 2006 | 07:06 PM
TxStangDude's Avatar
I have that problem in my '05. I know others who have had the same issue.
The probelm is in the steering between the wheel and box. If you grab the steering shaft and shake it, it has movement and you can hear/feel the slack.
If under warranty, dealer will fix it.
Old Nov 10, 2006 | 08:20 PM
Lightbulb
CLICK CLICK CLICK = bad C.V. axle! Basically the constant velocity joint is coming apart under the rubber boot.
Which one it is, will be your sense of ears. Have you looked at your C.V. boots? Check to see if they are torn open or signs of grease coming out.
IMO, I think its that.
Jim
Old Nov 10, 2006 | 08:24 PM
It's a 2000 Silverado. No more warranty. Could be the intermediate steering shaft gone dry.
Though it probably has quite a few miles on it. That's why I'm thinking C.V. axle.
A few more things to check: Upper & Lower balljoints, inner and outer tie rods, and hub bearings (they have been quite known to go out).
Jim
lukn4trbl355
Oct 21, 2015 11:19 PM
turbo6c3
Oct 5, 2015 06:11 PM
Infernohoe
48
Oct 2, 2015 10:25 PM
Velocity1
Oct 2, 2015 08:01 AM
tim wellington
Sep 29, 2015 10:17 PM
