Why the hell
Old Mar 28, 2012 | 02:38 PM
TXsilverado's Avatar
try firming up your rear shocks and let us know how it does.
Old Mar 28, 2012 | 06:25 PM
mhotrodscooter's Avatar
Originally Posted by skeet
i like the ole John Force burnouts!!!
Scooter i take it you wont be in town this weekend?
i believe youre right on the rims being 8" with a 10" wide tire!
Yeah I like those too, but when it starts pushing what can you do?
I leave this weekend so no racing till 3 weeks. Btw pinion angle is at -3 degrees.
Old Mar 28, 2012 | 06:28 PM
Tried that.. What else you got? Your the man I look up too.
Old Mar 28, 2012 | 10:12 PM
Beatdown Z's Avatar
Laid Back
How tight are your bars and are they in the upper or lower hole?
Old Mar 29, 2012 | 08:23 AM
I've tried preloading them by 2 faces, barely touching, and 1/2' off the leafs. Bars or in the bottom hole parallel with the ground.
Old Mar 29, 2012 | 09:21 AM
i know it sounds crazy, but try spraying a bigger shot out of the hole. my buddy has a car that wont hook on motor, but will pick up the tires hitting a 250 shot out of the hole. i guess it shocks the tires into hooking. this was my next plan of action with my truck before i took it apart.
Old Mar 29, 2012 | 05:04 PM
Beatdown Z's Avatar
Laid Back
Putting the bars in the upper hole will hit the tires harder and the more preload you add, the harder the hit.
Old Mar 29, 2012 | 07:07 PM
I can understand that, but where all missing something here. I've cut 1.74's on stock suspension with dr's. With less power then I'm making now. So I'm just dumbfounded in why I can't do it with slicks. Is the sidewalks soaking up to much? Should I go back to a dr's?
Old Mar 29, 2012 | 07:13 PM
I readed the samething on yb, but I'm not even close to my stock suspension times yet. It's got to be the softer sidewalls that is hurting me.
Old Mar 30, 2012 | 08:19 PM
Nobody has had this problem?
