who runs tubes in m/t et streets?
Old Apr 17, 2006 | 11:18 PM
goshawk23's Avatar
Truck addict
Default who runs tubes in m/t et streets?
i ordered a new set of et streets and was wondering who all buys the tubes for these things. guy on the phone at summit acted like i needed them bad, even though the current set of et's i have don't have them. i know of others that don't run them. what gives
Old Apr 17, 2006 | 11:19 PM
white1's Avatar
I dont
Old Apr 17, 2006 | 11:23 PM
goshawk23's Avatar
Truck addict
summit wants like 59 bucks each tube. F that. i have never run them and don't want to start now. i'm already pissed at them cause they didn't process my order. i ordered the damn tires the other day. went to check and no order exist. hmmmmm, i'll be watching my checking acct.
Old Apr 18, 2006 | 05:51 AM
bud8fan's Avatar
Originally Posted by white1
I dont
me either....
Old Apr 18, 2006 | 06:45 AM
Cuerva's Avatar
11 Second Truck Club
It is a tubeless tire afterall. I would only run a tube in it if you get a tire punctured, (been there) other than that just keep up with air press.
Old Apr 18, 2006 | 06:58 AM
Dock Rocker's Avatar
I am not sure about the ET's but on a real slick if you dont use a true rubber tube you are in for a hell of a ride. I tried this b/c I could not get a good seal at low pressure 10 to 12 lb and I went to the wall. I could not figure out why the hell my handling went south all of a sudden. Swapped a buddies slicks (no tube) and it was fixed. After doing my home work a synthetic rubber tube will not fill the slick fully when it expands (ie leaving the line) apparently the natural rubber will. I never found out for sure b/c I went and bought new wheels the next week as I have an aversion for walls at drag strips
DOCK
Old Apr 18, 2006 | 08:41 AM
bluecajun5.3's Avatar
no tubes w/ the et streets. i run them at 15lbs at the track. what size you ended up going with.
Old Apr 18, 2006 | 11:40 AM
goshawk23's Avatar
Truck addict
i ended up with the 28" 11.5's. vice the 26" 10.5's that i have now. little more tire to the ground and not so short. it might help me out going down the track some. i was rolling them little tires like crazy
Old Apr 18, 2006 | 12:25 PM
closet red neck's Avatar
What size tire do you think with a 4.56:1 gear, 4L60E and a big cam?? I know....what cam and yaddayaddayaddayaddda.....I was just getting some opions or ball park estimate.
James
Old Apr 18, 2006 | 03:28 PM
well i'm running a 26x11.5 tire w/4.10's right now and they pretty much can't hang w/ the motor. sometimes it hooks and sometimes it doesn't. even with minimal spin or hooking, the truck is shifting out of 1st right pass the 60' mark. its also shifting to 3rd a ways before 1/8mi. when these are done i'm probably going with a 28x11.5 m/t drag radial or similar. going with a taller tire my bottom end should stay the same or better if i don't spin, and should pick up in the midrange and topend. for 4.56's i would have to say 28" tall tire but i'm no expert.
