What are you guys doing for the rear and driveshaft?
Old Mar 18, 2012 | 03:17 PM
david068513's Avatar
Default What are you guys doing for the rear and driveshaft?
What rearend setups are you guys using? also what about the driveshaft? how much can a stock driveshaft take?
Old Mar 18, 2012 | 05:51 PM
Beatdown Z's Avatar
Laid Back
What do you mean by "rear end setups"? what's inside the differential or the suspension?
Old Mar 18, 2012 | 06:18 PM
what housing, internals etc.
Old Mar 18, 2012 | 06:24 PM
quicksilverado's Avatar
How much power you planning on David?
Old Mar 18, 2012 | 06:51 PM
Hoping for 500rwhp right now but want it to be strong and not worry about breaking it. Gonna order a kb Turbo kit with the 70mm kit(thinking of maybe getting a 76mm though)and just run some meth for right now.
Old Mar 18, 2012 | 07:24 PM
BlackGMC's Avatar
Resident Retard
I went with a Drive Shaft Specialist 4in 0.120 wall Aluminum driveshaft with my 80 swap. It has built for 1350 ujoints and yoke up front, but the rear ujoint is a hybrid 1350/stocker. When i redo my pinion gears i am gonna swap it out for a solid 1350 and new pinion yoke.
Old Mar 18, 2012 | 07:45 PM
Get the stock drive shaft high speed balanced and it will be fine. An aftermarket posi in the rear will do too.
Old Mar 18, 2012 | 08:51 PM
Beatdown Z's Avatar
Laid Back
I'm running a used Eaton Posi, used GM 4.10 gears, new bearings, carrier bearing cap studs. I do plan on adding a girdle cover in the future and maybe even some braces after seeing Turbo Mic's bent Moser rear axle.
Driveshaft is currently stock, but I plan on getting with Driveshaft Specialist for a new one with 1350 joints.
BKnBLK05
Dec 28, 2015 08:52 PM
Go5.3tt06
Sep 12, 2015 09:29 AM
fillpot
Jul 26, 2015 07:21 PM
lxcoupe
Jul 21, 2015 02:12 AM
GM-only
Jul 19, 2015 10:48 PM
