What year 4l80e do I have?
Old Mar 21, 2014 | 02:27 PM
nickleahy23's Avatar
Default What year 4l80e do I have?
I picked up a 4l80e. It came out of a 2002 silverado (i saw the truck as they were pulling it out). I keep reading that after 1997, they moved a trans line fitting to the back of the trans? Mine has both holes on the side. What year do I have? Im trying to figure out what fittings I need for my -6an lines since the newer ones require the one with the tube. Thanks.
it says GM-B9 in the casting
Old Mar 21, 2014 | 02:35 PM
03sierraslt's Avatar
That's a 2002, one line on front and one at rear (red caps) the 2BSP signifies it's a 2002.
Old Mar 21, 2014 | 02:38 PM
malibu795's Avatar
russel part # 640520 1/4 NPSM to -6an...
Old Mar 21, 2014 | 02:41 PM
In fact it came out of a 2002 6.0 K series.
Old Mar 21, 2014 | 02:48 PM
awesome haha. Thanks guys. I guess the "moved a fitting the rear" threw me off as its the first time ive really looked a 4l80e out of a vehicle
Old Mar 21, 2014 | 02:49 PM
found these
6AN 4L80E GM Transmission Cooler Fittings | eBay
Old Mar 21, 2014 | 02:53 PM
Ferocity02's Avatar
Originally Posted by nickleahy23
Yep those are the ones that you want if the cooler fittings are spaced apart. If the fittings are both the front then you need different fittings.
Old Mar 21, 2014 | 02:54 PM
Ferocity02's Avatar
I think those are for the early year 80E's.
Old Mar 21, 2014 | 02:59 PM
Correct, that Russell part number is not for the newer style. Do not use that.
Old Mar 21, 2014 | 05:11 PM
greasemykey's Avatar
what is the difference in fittings? my trans looks just like that but it did not of have top bell housing bolt hole. i hope i have the right fittings.
