What is a Shift Silenoid
Old Jan 26, 2005 | 08:14 PM
CAMMIN03''s Avatar
Banned
Default What is a Shift Silenoid
My buddy just had a torque converter put on. He has the 2003 SS silverado.
He had his new PCMforless tune put in... It ran fine yesterday (transmissionwise)
And tonight the engine light popped on and his rpm's wouldnt go above 2000 and
the truck would barely moved.. So we went to Autozone and the scanner said
he had a Shift Silenoid Stuck Open.... What exactly is that... and will it hurt
thing to keep running the truck? Its driving fine now and only did that not
moving deal one time but the light it still on?
Old Jan 26, 2005 | 09:16 PM
CAMMIN03''s Avatar
Banned
???anybodyknow????
Old Jan 26, 2005 | 09:19 PM
The solinoids on an electronicly controlled transmission receive signals from the PCM to open and close the fluid hydraulic passages that control the transmission.
Old Jan 27, 2005 | 12:08 AM
Black Blown 02's Avatar
What size stall did he get?
When I went from my 3000 to a 3800 stall, it would throw the PO757(I think) shift solenoid stuck-on code. It is a limp mode the trans goes into when the PCM detects too much converter slip. It holds the trans in 2nd and 3rd gear until you clear the code. You have to turn that code off in edit or have your tuner do it, and it won't happen again.
Old Jan 27, 2005 | 12:16 AM
CAMMIN03''s Avatar
Banned
it is a yank 3000 with transgo shift kit and corvette servo
Old Jan 27, 2005 | 12:24 AM
It usually happens with stalls bigger than 3000, but I've heard of it happening with a 3000 before. Find out the exact code, and get it turned off with a tune.
Old Jan 27, 2005 | 07:37 PM
v8
17,16,15,14,13,12,11 Drvr
just have auto zone reset the code and you should be fine mine did the samething 2 weeks ago i reset it and its been fine since just something in the air i guess because xfactor had the same code about 2weeks ago lol reset his and haven't heard from him that its back on later,kevin
Blwn99x
Mar 24, 2023 11:14 AM
RustyD
May 23, 2016 07:04 PM
Wolftrk99
Dec 3, 2015 08:12 PM
Cammed4ever
Sep 30, 2015 03:38 PM
sTNT971
Sep 26, 2015 06:27 AM
