what paint to use on frame???
auto parts stores, or Ace hardware, . . . if not they can order it. on their site. . . . I'll send you a PM.
Prep the surface with a wire wheel.
Wipe the surface with rag and break clean or some other non-oily solvent cleaner
get the gloves on and start painting.
Any one Every use PPG's DP90 Epoxy primer on a Frame ???
I just rebuilt a suburban and after the frame repairs were done, I used a Hot water presurewasher to remove the factory wax type coating and also a wax and grease remover once I got it to look like bare metal... I then sent it over to a local sand blaster and had it blasted clean so I could paint it. That also took care of any heavy rust that was present. I just left it in dp 90 since its Like a mat black. Because it is epoxy based it bites into the metal. was thinking about apply a rock gaurd spray from SEM or that but I have never used that stuff. still looking for possiblits for a top coating for log term protection. possibly an epoxy based bedliner spray....
gmcyukon
Oct 3, 2015 11:03 PM
Cha_Feel_
Sep 23, 2015 09:06 PM
