What happens when an Eaton posi goes out?
Old Aug 26, 2008 | 05:14 PM
CashDudeHomie's Avatar
Default What happens when an Eaton posi goes out?
Does it just spin one tire, or does it make grinding sounds when turning? Mine has been grinding lately. I think it's almost time to retire the damn truck.
Could it be the full-synthetic oil the guy who put my new gear in used? Yes we did use the friction additive.
I bought some regular oil and more additive for it, but haven't had time to change it yet.
Old Aug 26, 2008 | 05:31 PM
parish8's Avatar
single digit dreamer
pretty sure you are suppose to use synthetic with the stock rear.
my diff just blew to pieces when it went bad. took out everything. i would expect a grinding noise to be something other than the g80. bearing or brakes.
Old Aug 26, 2008 | 05:58 PM
It's an aftermarket Eaton 8.5" with the clutch packs. The sound only happens when turning and is coming from the back, so I assume it is the differential.
What do you think? Do the aftermarket clutch pack differentials wear out differently than the G80?
BTW I still have your ASM headers on my truck from WAY back in the Whipple days
Old Aug 26, 2008 | 06:16 PM
zippy's Avatar
If you're referring to the aftermarket (not a gov-lock) version of the differential unit you can't run synthetic in there. You have to run non synthetic with the additive or you can get groaning with possibly clutch slippage.
Old Aug 26, 2008 | 09:20 PM
Truckshop's Avatar
service it and add the friction modifier and it will be fine.
Old Aug 26, 2008 | 10:53 PM
James B.'s Avatar
I run straight 80/90 non-synthetic and always have with my Eaton posi. They are definately not compatible with synthetic. Mine doesn't require friction modifiers but the instructions for the 10.5 may be different from the 8.5/8.6.
Old Aug 27, 2008 | 07:41 AM
BigKID's Avatar
I broke some teeth off the spider gears in my Eaton Posi but it would catch and pop at anything other than absolute straight rather than making a grinding sound. Rebuilt it with new spider gears and all is well thus far.
Old Aug 28, 2008 | 01:32 AM
It was the oil. I changed it today to regular oil and it instantly stopped. I told the guy when he fixed it that I didn't think synthetic was a good idea, but he said it would be ok. Guess I proved him wrong lol.
The synthetic is just too slippery for the clutches.
Old Aug 28, 2008 | 01:37 AM
95 bright teal's Avatar
glad to hear its fixed, i hate little hang ups like that but i guess that is how we learn right?
Old Aug 28, 2008 | 02:24 AM
Parke10's Avatar
almost was an expensive way to learn..
