What caused my driveline failure?
Old Jun 19, 2015 | 08:16 AM
BIGDADDY1969's Avatar
When i put my DSS one piece it was a bitch to put both clips in but you need the clip on both sides.
Old Jun 19, 2015 | 09:07 AM
Gadgetized's Avatar
Originally Posted by 1bdbrd
New Question
Does the U joint on the rear axle use both of the clips to hold it in place? When I put in the U joints I could only get the clip to fit into the axle uoke on one side. Could this be the cause of everything??
Yes, that's what did it. From what you had described it sounded like the clips weren't in. When they come from the factory, they don't use a clip. They use heated plastic to hold the caps in. You need to heat the caps so the plastic will loosen and then you can remove the caps. When you didn't heat it, and pressed them out I'm sure you bent the ears, probably to the point where you couldn't get the one clip in. When there was no clip in it, centrifugal force threw the cap out causing it to vibrate. It just got worse from there...
Old Jun 19, 2015 | 02:57 PM
That sounds so logical I'm gonna roll with it.
Couple weird things though. This is like the 3rd or 4th set of u joints that truck has had and it's been stock height all its life. Couple that with the driveshaft not having either clip on the rear uoke when I pulled it off. Was that just an extreme case of luck that it went like that for 3 or so years?
SloSVO
Nov 22, 2020 07:34 PM
bearden86
26
Nov 15, 2015 03:58 PM
Velocity1
Oct 2, 2015 08:01 AM
Slammed silverado
Sep 28, 2015 06:14 PM
iregret
Sep 7, 2015 01:20 PM
