Well Installed The Corvette Servo And Now I Need New Tranny
Install was a breeze only I used the longer pin . Drove it yesterday everything fine felt good. Today drove it about thirty miles to work great. Left work and about 2 miles down the road it didn t shift out of third looked back white smoke. Pulled over two hours later get it home and get under to check the cae where the snap ring is held broke.........cant fix that the case is broken.
Anybody use monster tranmission before? Also need the right stall for torque converter i have "oldman cam from thunder" please help need to get back on road.....
I feel your pain, the exact same thing happened to me a week ago. You didnt get that big ring seated in the SECOND groove.....theres two, you and I both put it in the first one. Ron
Your case also broke?
Kiser...The install is very straightforward. The RE-install is the only thing you have to be careful about. The large metal "snapring" really isnt a snapring at all, but looks similar. It fits in a groove to hold everything in, its the last piece you put in place.
The problem is that there are actually two grooves, one sits closer to the outside edge of the transmission case, the other back slightly farther. Be sure you get it in the SECOND groove.
I unfortunatly learned this the hard way and now have to try to convince the wife that I am not retarded, and really can be trusted to continue to work on things
Originally Posted by kiserhd
Could you guys please elaborate on what you did wrong? I just bought a vette servo and plan on installing im the next week or so.
Heres a trick that atleast helps in making sure the servo is fully seated. Take a rubber mallet, and give it good swift wack or two After you've installed the retaining ring, that usually makes sure its fully seated.
