Well....... crap.....
11 Second Club
I ordered up a Yukon duragrip and some US Standard gears in 5.13 ratio in preparation for an upcoming T56 swap. Well I finally got around to installing them in the driveway today. Got it almost all the way done and was trying to install the axles when I found this... Can't get the pin out of the damn carrier to install the c-clips. WTF???
Anyone ran into this???
Mike
Mike
11 Second Club
The bolt is out for pin. The pin is hitting the gear and impossible to remove from either side of carrier.
Mike
11 Second Club
Well I just talked to Ron at Rons Machining Service where I bought the gear/posi package from. I guess the industry standard is to grind the gear down off the corner without getting into the wear pattern. They even have a video on their website showing the procedure. I'm going to remove the carrier tonight and instead of grinding the gear, I might machine a flat along the length of the pin. This way the ring gear stays in tact. Seems like a more logical way to approach this problem IMO.
How to grind a thick ring gear to clear the cross pin shaft - YouTube
Mike
Mike
