welding up the 10bolt???
i've read where people have welded up the 10bolt center chunk to the axle tubes. can this help with strength? and during welding can you go all the way around in one shot or do a inch or so at a time going from one side to the next? i have a lincoln mig i can use. is there anything else you can do to the housing to get it to flex less?
do you have a 110 or 220 welder? If you have a 110 I would not even attempt it, but that is just me... Are you wanting to put some brace that connects inbetween the housing and tubes?
well i read that someone had there actual center chunk spin on the axle tubes. he's on here. he said when he had it fix they just moved it back striaght and welded it up and studed it somehow. i know they make a girdle too but i don't have money for that right now. so just looking for basic "free" mods to do. i think its a 110 so even if i turn it up you don't think it will weld it?
what about a big stick? he has one of those too but its been awhile.... stitch welds? don't mean to sound dumb. not up on all the welding lingo. i do mostly just exhuast systems. kinda learn as i go. i have a book
I would not trust a 110 welder past 1/8 steel... But that is just me, on my 220 welder I only go up to 3/16, anything over that I don't feel comfortable welding with a mig... Depending on the thickness of the case and tubes you might be able to do it with the biggest flux core wire you can find with the welder turned all the way up.... More than likely you could only weld a 10-20 seconds continously then wait about 5-10 before welding again because you will probably exceed the welders duty cycle.... Just make sure the metal is absolutely clean and wipe it down with acetone before... Just my .02.....
That would cause too much heat and probably warp the tubes... More harm than good there....
Really the only option I would consider since it is 1/4 thick would be a tig welder, it can weld that thick but it does it alot colder than a mig or stick...
Sorry to shoot down your ideas, you could risk ruining your rear end, IMO...
found it. looks like they are .250, 1/4" thick. http://www.cj7jeep.com/info/axle/tub_thickness.html
