Viking shock lower rear mount issue
Old May 5, 2018 | 03:04 PM
meatwad's Avatar
Fast lane preferred
Default Viking shock lower rear mount issue
Got the coilover kit from atomic and decided to put the Viking double adjustables on the rear as well. On the lower mounts, the shock body slightly contacts the mount, pic below.
Safe to run them like this, or do I need to modify the mount?
Old May 5, 2018 | 04:02 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Can you spread it and get 1 more washer in there?
Is it only rubbing on 1 side?
Old May 5, 2018 | 06:01 PM
meatwad's Avatar
Fast lane preferred
It’s rubbing on both sides. I would have to persuade it to take more washers, but i would need a bigger hammer.
The picture is from the driver side. It’s even tighter on the passenger side.
Old May 5, 2018 | 06:14 PM
brandon6.0's Avatar
Do like i did and add some washers to the bolts on the bracket to the rearend. That will spread the lower shock mount apart as well. Thin shim with more washers for the shocks.
Edit nevermind i thoughy u was using relocated shock mounts. Take a large adjustable wrench and pull the brackets apart some.
Old May 5, 2018 | 06:32 PM
meatwad's Avatar
Fast lane preferred
Yep, I am using stock mounts. I’ll crank on it and stick some more washers in there tomorrow.
Thanks for the suggestion with the wrench.
Old May 5, 2018 | 10:31 PM
06sierra5.3's Avatar
Atomic makes some weld-on rear shock relocation kits, if you can't get this where you need it, that might be the way to go
Old May 6, 2018 | 07:16 AM
ILuvJDM's Avatar
I have the same issue, just run them and they will develop little wear marks and clearance themselves
Old May 6, 2018 | 01:17 PM
meatwad's Avatar
Fast lane preferred
I was able to spread the mount and get another washer in. Very little clearance but there is some. Now to start playing with settings.
Thanks for the input.
ILuvJDM
Apr 24, 2018 04:14 PM
Atomic Performance
Mar 21, 2017 06:19 PM
sTNT971
Jan 9, 2015 05:26 AM
