Vig Install?
Old Jan 15, 2006 | 09:09 PM
DrX's Avatar
DrX
Default Vig Install?
Ended up with about 3/8" between the TC and flexplate so I had to use some washers for a total thickness of about 5.7mm to prevent pulling the converter out. I reused the stock bolts because the ones that came with the converter were way too short. I cut down the conical tips on the bolts to ensure that they wouldn't jam in the blind end holes in the TC before the TC was drawn up tight agaist the flexplate and that I got as much thread engagement as possible.
Does this look OK?
Attached Thumbnails Vig Install?-trans-015.jpg   Vig Install?-trans-022.jpg   Vig Install?-trans-023.jpg   Vig Install?-trans-027.jpg
Old Jan 15, 2006 | 09:13 PM
99Silver6.0's Avatar
Your good to go. Same as what I did.
Old Jan 15, 2006 | 10:16 PM
KySilverado's Avatar
Seems to be a common thing with the VIG.
Old Jan 15, 2006 | 10:42 PM
Id shim any AM converter I used if it needed it.
LCHEE
Oct 24, 2020 04:10 PM
GXPJAY
Nov 5, 2015 06:49 AM
zblee
Aug 3, 2015 03:45 AM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
