vibration on take off..... help please!!
From: Where our street cars are faster than your racecars..Mississippi
OK... i been building a truck for a couple months and i never drove it before...
it is a 2003 EX-cab only thing i did to the suspension is a set of 2" shackles...i put a 6.0L in it other than that it is 100% stock and if i take off with anything ove 1/4 throttle it has a vibration you can feel in the whole truck its not HORRIBLE but cery noticible.. what could this be... its really getting on my nerves and don't have the money to just start changing parts..
i want to fix this ASAP!!!!
it is a 2 piece... and the carrier bearing seemed OK but how do i NEED to check it? is there supposed to be any slack or non???
and the vibration is worse harder i mash on the loud petal... but is i had to pick between shimmer or a solid vibration... i would say its a solid vibration...or maybe a shimmy...lol
with the DS bolted up you would check for slack in the carrier. if the rubber part is worn out or the bearing is not smooth when spinnig it would be things to look for. but I would look at DS angles, may need a carrier shim to get the DS back in line with the right working angles.
