Valve body: School me
Old Nov 4, 2010 | 10:51 PM
00Silv4.8's Avatar
Default Valve body: School me
Like I said, haha tell me everything there is to know about a valve body (4L60e).
I am pretty certain my trans needs a valve body. I am curious about a few things:
Is it hard to install/remove?
Will I need to devote a day to it or a couple hrs after work?
What year should I look for with metal pistons? (I wanna say it may be the accumulator? Its pretty common to fail in early 00's, so Im told)
I will be doing a shift kit along with it. Should I be ok with reusing the separator plate?
Thanks guys
Old Nov 5, 2010 | 02:14 PM
48548's Avatar
I also put in a HD-2 kit.... Not bad, I installed a new accumulator pistons aluminum as well and a new pinless forward. I also installed a new separator plate and sonnax 2-3 hd shift valve along with a corvette servo and thorlon check ***** to replace the metal that would wear a hole in the plate. I did it in my garage in phx not bad nice to have a someone help to double check things.... I also ordered a nice click 1/4 torque wrench as well to use. I would go with a new plate. My only had 18,000 miles on it but still showed some wear. I would devote a day as well to take your time and double check your work. I couldn't install the corvette servo unless I installed it in pieces with the pin installed in the truck as it was to long to take out in one piece and hit on the servo's. I used the kent moore tool that holds the cover in and it really helped me out a lot.
Old Nov 5, 2010 | 02:17 PM
48548's Avatar
Also I ordered everything from a guy who made up the kit for me with everything I wanted. It was around 160.00 or so and he drilled the new plate as well, I just had to install and drive it away. He put together new pins and pistons along with the pinless forward and thorlon check ***** and seperator plates and new one piece seals for the pistons as well. He could provide the corvette servo as well if needed. I am not a guru but could provide help if needed.
Old Nov 5, 2010 | 02:22 PM
00Silv4.8's Avatar
48548, I may be interested in using you to crossreference or give me a hand if you dont mind. I plan on getting the valve body hopefully by next month and getting it in ASAP. Got some email's from a buddy of mine I need to review as well.
Old Nov 5, 2010 | 03:31 PM
48548's Avatar
Here is where I got the kit.... Call Dana up and tell him what you want and he will get everything needed in one box minus the filter and fluid.
http://www.700r4l60e.com/
Here is link for the kits and shows what other stuff he puts in it as well and prices also.
https://www.700r4l60e.com/store/home.php?cat=64
Old Nov 5, 2010 | 03:38 PM
48548's Avatar
I researched a lot of stuff and I made a few mistakes and had to take my vb off a few more times, but I won't make those mistakes again and also FLT was very helpful in advice and they might be able to hook you up with a kit as well, they helped me with a slipping code due to me putting in a valve backwards. Also I have a 2005 silverado ECSB 4x4 that I installed the kit in.
Michael
Wolftrk99
Dec 3, 2015 08:12 PM
00loudchevy
Dec 3, 2015 05:54 PM
Avalanche2002
Nov 30, 2015 07:31 AM
JordanH
Oct 3, 2015 03:59 PM
Velocity1
Oct 2, 2015 08:01 AM
