vacum mod ???????
Old Nov 19, 2006 | 07:31 PM
ogkevin13's Avatar
Banned
Default vacum mod ???????
i have a 60e tranny with trans go shift kit and vac mod what happins if the vacum mod has a leak or is not working properly???? my problem is when i get to about 15-17 hg vacum the rpms surge up like if the torque converter gets out of lock up??? need help please also i will be running 10-12psi of boost on this tranny will it hold up?? i usually just cruise it but if i take it to the track for a few runs i want it to hold up
Old Nov 19, 2006 | 07:47 PM
Quik's Avatar
5 year bitches!
i had a leak and it shifted wierd. the little hose they give you isnt up to par IMHO. if i ever use a A4 again and this mod ill try and get a better line made to hold up better
Old Nov 19, 2006 | 09:57 PM
04Denali's Avatar
If you loose vacuum it will shift at max line pressure, Very hard, neck jerking shifts
Old Nov 19, 2006 | 10:20 PM
FLT's Avatar
FLT
FormerVendor
Where do you have it connected? Does it see boost or do you have a vacuum blowoff valve? This set up must not see boost!
Old Nov 20, 2006 | 06:17 AM
TG02Z71's Avatar
Just saw this post, where is a good source for a vacumn signal?
Where is the factory signal coming from?
Old Nov 20, 2006 | 06:59 AM
FLT's Avatar
FLT
FormerVendor
Normally it gets tapped into the break booster hose. If you are running a radix I have been told that the J-tube is a good place to tap into because it does not see boost.
Old Nov 20, 2006 | 11:35 AM
ogkevin13's Avatar
Banned
yes mine is tapped in the brake booster hose and since its fi it has the check ball valve in!!! and yes its does boost!!! what exactly is a vacumn blow off valve do i need it? or do u guys just think its a leak?
Old Nov 20, 2006 | 08:42 PM
FLT's Avatar
FLT
FormerVendor
Do you have the transgo vacuum blow off valve? Sorry I'm a little confused.
Old Nov 20, 2006 | 09:05 PM
ogkevin13's Avatar
Banned
no i dont
Old Nov 20, 2006 | 10:18 PM
FLT's Avatar
FLT
FormerVendor
Is your blower new?
