Update: 2 PC DS CONVERSION, PICS INSIDE
Old Feb 5, 2008 | 08:55 PM
  #21
hmatiak's Avatar
Originally Posted by Truckshop
correct. the crew has no crossmember cause it has a one piece shaft. the extended cab has the crossmember cause of the two piece shaft. where did you get the shaft from and how much did you pay for it?
I got it all for a steal: the 2 shafts, bearing, and crossmember for 200. all from a local junkyard
Old Feb 5, 2008 | 08:56 PM
  #22
hmatiak's Avatar
Originally Posted by KySilverado
I may be doing the 2 pc shaft at some point. Since dropping the truck I have a vibration that comes and goes. My truck is an x-cab, has a one piece shaft and also has the cross member in the photos less the actual plate to bolt the bearing support to. I am hoping that I can find a 2 pc unit the right length and then only have to weld in the flat bearing support plate to my crossmember to make it work.
You've got it easy then. all you need is some 1/8th in plate with some slotted holes to weld on and the shafts
Old Feb 5, 2008 | 10:40 PM
  #23
1989k1500's Avatar
Sweet.
Old Feb 6, 2008 | 04:39 AM
  #24
Blown02Sierra's Avatar
Have you installed it yet?
Is there another factory 2 piece that would work on a 4wd ecsb?
Old Feb 6, 2008 | 07:46 AM
  #25
hmatiak's Avatar
Install was finished this past weekend. Not sure about you app. Your one pc DS is allot shorter than what i had. Im sure you could have a setup made, but a factory swap, dont think you will find it, but i could be wrong. Pull a tape on it and call around.
Old Feb 6, 2008 | 11:49 AM
  #26
Dirty 30's Avatar
LS1Tech Whore
Has anyone shortened a single piece DS like this one and installed it on a single cab standard bed truck?
Old Feb 6, 2008 | 12:06 PM
  #27
hmatiak's Avatar
Not sure, but i dont see why a DS shop couldnt manage it. Go price a custom DS, they arent cheap
Old Feb 6, 2008 | 12:14 PM
  #28
Dirty 30's Avatar
LS1Tech Whore
Well i have a custom steel driveshaft now, cost me $275. Just wondering if that fat one would be better than the one I have now.
Old Feb 6, 2008 | 12:42 PM
  #29
hmatiak's Avatar
im not an expert on it, but i want to say the design is supposed to be stronger, and its also lighter. might want to look around about it
Old Feb 6, 2008 | 05:38 PM
  #30
80z28s6's Avatar
Hmatiak, with the new 2 piece shaft in place, have you turned off the speed limiter in the computer? I got a ECSB 99 with the factory 2 piece and was wondering if anyones had trouble with these popping out and screwing up the tranny.
