Update: 2 PC DS CONVERSION, PICS INSIDE
Old Feb 4, 2008 | 07:44 PM
hmatiak's Avatar
Originally Posted by Truckshop
did you have to modify the length any?
length of what?
Old Feb 4, 2008 | 07:45 PM
hmatiak's Avatar
Originally Posted by KySilverado
I'm curious why you didn't use the existing cross member for the center bearing support?
what existing crossmember? i had a one pc ds before
Old Feb 4, 2008 | 07:47 PM
hmatiak's Avatar
if you mean the DS, nope it's within a inch of the same length. you also have two slip points on the new setup, so there is plenty of places to compensate for just a inch diff
Old Feb 4, 2008 | 10:09 PM
SBTork's Avatar
wow, good idea
Old Feb 5, 2008 | 06:21 AM
agreif's Avatar
gas tank didn't get in the way of cross member at all?
Old Feb 5, 2008 | 07:24 AM
hmatiak's Avatar
I mounted it just forward of the tank. I didnt show this in the pics, but i had to weld a 6 inch pc of plate on top of the 3x3 tubing to push the midshaft bearing a little farther to the rear. Then just drilled the holes in the plate for mounting.
Old Feb 5, 2008 | 01:52 PM
KySilverado's Avatar
Might be different on a crew... but in the extended cab the crossmember, that looks like you cut out, is used for the bearing support.
Old Feb 5, 2008 | 02:10 PM
hmatiak's Avatar
Its differnet. Picked that crossmember up thinking i could use it, but the frames are different and the tank is in the way.
Old Feb 5, 2008 | 06:30 PM
Truckshop's Avatar
correct. the crew has no crossmember cause it has a one piece shaft. the extended cab has the crossmember cause of the two piece shaft. where did you get the shaft from and how much did you pay for it?
Old Feb 5, 2008 | 07:03 PM
I may be doing the 2 pc shaft at some point. Since dropping the truck I have a vibration that comes and goes. My truck is an x-cab, has a one piece shaft and also has the cross member in the photos less the actual plate to bolt the bearing support to. I am hoping that I can find a 2 pc unit the right length and then only have to weld in the flat bearing support plate to my crossmember to make it work.
