u-joint question
Old Apr 28, 2011 | 04:53 PM
getchusum99's Avatar
Default u-joint question
i have a 99 nbs silvy z71 , with a manual t-case. i replaced my ujoint on my rear diff to driveshaft yesterday. i was wondering if the new one was supposed to have the c-clips that go on the caps? i am speaking of the caps that bolt to the rear diff with the 2 bolt straps. i didnt put them in because i didnt think i needed em, and my driveshaft fell out due to the caps moving past the straps. the one i took out only had the clips on the caps that actually go into the driveshaft itself.
Old Apr 28, 2011 | 04:58 PM
budhayes3's Avatar
PT's Slowest Truck
I replaced my u-joints with factory replacements and they had clips to retain them...what kind of u-joints are you using, and did they come with new clips? (mine came with new clips)
Old Apr 28, 2011 | 05:03 PM
chevyrace47's Avatar
there are a few ways the caps stay in place. either the metal clips i think you're referring to, that are somewhat circular and goes on top of the caps. there are also c-clips that go on the inside of the yoke and slip into the bottom of the cap. those are how it usually fastens to the driveshaft yoke. now the rear end and tranny yoke(if its not a slip yoke) use the straps with a little flat stub to hold it in place, you shouldn't need any clips for this.
Old Apr 28, 2011 | 06:27 PM
my driveshaft just fell out, no B.S. , while i was going to the gym,5 mins ago. fml. luckily i was only 3 miles from the house, so i just put it in 4hi. its a carquest gold, replacement, it came with clips, but i put those on the driveshaft side, or the side you press in. was i wrong? they were the half moon or c-clip type clips
Old Apr 28, 2011 | 07:14 PM
ive looked at a bunch of online parts stores, and it looks like i have the ujoint for an extended cab.
Old Apr 28, 2011 | 07:30 PM
there should be something on both driveshaft and rear end yokes. if it doesnt have those tabs on the yoke or a groove then it takes the c-clip
Old Apr 30, 2011 | 08:53 AM
yep, it was the wrong ujoint . i put the right one in there and no problems, thanks guys
JordanH
Dec 25, 2015 08:32 AM
spooneralmighty
Sep 11, 2015 02:28 PM
chevstang421
Sep 10, 2015 09:16 AM
iregret
Sep 7, 2015 01:20 PM
