u-joint caps
Old Nov 12, 2007 | 05:55 PM
brent1976's Avatar
11 Second Club
Default u-joint caps
Does anyone make a heavy duty u-joint cap for trucks?
Old Nov 12, 2007 | 06:54 PM
silveradol33's Avatar
the cap? or the strap over that cap? Im gonna say no on the cap, prolly just a bigger 1350 series u joint. How did u break that cap? wow........
Old Nov 12, 2007 | 07:32 PM
brent1976's Avatar
11 Second Club
I was wrong, not the cap the strap that holds it all in. I want to get new u-joints before I beat the hell out of this thing. The stock straps I'm sure are strong enough since the joint itself sits in the yolk, but want something that looks stronger, just for kicks.
Old Nov 15, 2007 | 12:24 PM
20002wdchevy's Avatar
14 Second Truck Club
Ive seen a strap of sorts that was machined from a solid chunk and has divets for the u joint caps and it was closed on one end. I'll try and find you a link, i was also looking for something similar. also on a side note, what all do you need to step up to a 1350 u joint?
Old Nov 15, 2007 | 12:33 PM
i found it. http://store.summitracing.com/partde...5&autoview=sku im not sure it will work, but most 8.5 10bolt stuff will interchange with the 8.6wont it?
Old Nov 15, 2007 | 01:44 PM
ZZebes's Avatar
you would have to drill out your yoke, our yokes are threaded whereas the older ones used a u-bolt, ours are threaded
Old Nov 15, 2007 | 04:03 PM
TheChronic's Avatar
Just buy replacements from the dealer. They are like $2 and they're stainless steel. They aren't going to be a problem.
Pimpinpete
43
Dec 22, 2017 08:13 AM
OHsixLS3
Nov 22, 2015 07:45 PM
cheyenne383
Nov 13, 2015 09:24 AM
iregret
Sep 7, 2015 01:20 PM
