u-joint caps
I was wrong, not the cap the strap that holds it all in. I want to get new u-joints before I beat the hell out of this thing. The stock straps I'm sure are strong enough since the joint itself sits in the yolk, but want something that looks stronger, just for kicks.
Ive seen a strap of sorts that was machined from a solid chunk and has divets for the u joint caps and it was closed on one end. I'll try and find you a link, i was also looking for something similar. also on a side note, what all do you need to step up to a 1350 u joint?
i found it. http://store.summitracing.com/partde...5&autoview=sku im not sure it will work, but most 8.5 10bolt stuff will interchange with the 8.6wont it?
iregret
Sep 7, 2015 01:20 PM
