u joint 80e rscb
Old Nov 17, 2014 | 02:15 PM
Go5.3tt06's Avatar
I got all for flex plate. All good. Now I need find correct slip yoke
Old Nov 17, 2014 | 09:03 PM
726.0chevelle's Avatar
13 Second Truck Club
Its best to order the u joint after you have the yolk because there are different sized bearing caps. My th400 yolk came with 1310 or 1 1/16" outside clips. Or measure your u joint bearing cap and the c clip distance and order from there
Old Nov 18, 2014 | 07:36 PM
Go5.3tt06's Avatar
I spoke with guy on emails over about slip yoke. That he sell. Driveshaftspecialistinc.com
He says the slip yoke 3r and the u joint spicer XL will work fit on my steel driveshaft and 4l80e. Let me know if you think it's right one before I can order it.
Old Nov 19, 2014 | 08:02 PM
Go5.3tt06's Avatar
Anyone?? Hope you guys can help me. So I able get all parts to be here and able swap on my truck.
Old Nov 19, 2014 | 08:48 PM
mdwatts11's Avatar
Why not get the one I posted with a bastard u-joint? The 3r is weak and if you ever upgrade your driveshaft you'll have to replace the yoke with a 1350.
Old Nov 19, 2014 | 08:50 PM
mdwatts11's Avatar
Here's the joint you need also. 1350 to GM 3R Series Combination Neapco Greaseable Universal Joint
Old Nov 20, 2014 | 07:20 AM
Go5.3tt06's Avatar
Originally Posted by mdwatts11
Okay what about the slip yoke. Here T-400 & 4L80 Transmission Slip yoke GM 3R Series 32 spline w/threaded hole in output shaft
See if that correct one also?
Old Nov 20, 2014 | 08:12 AM
mdwatts11's Avatar
Looks like that will work to me. You just need a 3r u-joint if that's the one you are getting.
ls1curt
Jan 5, 2016 11:33 AM
Wrecker 426
Sep 30, 2015 09:39 PM
Lthompson
Sep 21, 2015 04:34 PM
MikeD.
Sep 17, 2015 09:39 PM
iregret
Sep 7, 2015 01:20 PM
