ARP 4L80e Flexplate/TC Bolt PN
I've looked and can't find the part number for the 80e flexplate/spacer bolts. I'm assuming they will be the same price as the oem bolts. Might as well get arp instead.
Also the arp 80e TC bolts if anyone has the part number.
Thanks in advance.
Thanks in advance.
Former Vendor
Are you using the crank spacer and the flat flexplate? If so the regular ARP bolts are a little on the short side. They are made to fit with just a flexplate, so when you add the spacer you do not get proper thread engagement. So you can use the longer OE style, 19257940. We also make a custom ARP bolt for use with our billet flexplate, which are longer and also work with the OE spacer setup. We have them in stock.
Circle D Specialties - CDS ARP LS Crank Bolts
Chris
Chris
Thanks Chris and Gadgetized. I am looking for the bolts for the flat flexplate and spacer. I was flipping through the catalog and noticed they don't even make them in the appropriate length for this setup, which surprised me. I will make it the last thing I buy, and depending on my budget I may just order those from you Chris.
I saw a picture earlier today but I lost it but it was one that Chris posted of the 3 GM bolts and the ARP one you had made. Do you have that so you could post it here?
slowlsx
08-10-2015 05:33 PM
