truck wont go in reverse after trans-go HD2 install
Old 10-31-2010, 09:57 AM
fredkj3's Avatar
Originally Posted by Vince @ FLT
One other thing to check is the boost valve. I have seen where the snap ring does not get fully installed and cause this issue as well. Recently I have seen some issues with the TG boost valve sleeve. Make sure that both holes do not have any burs in the holes on the outside of the sleeve. This could cause low boost pressure when in reverse as well. Good luck getting it all sorted out and please make sure to report back what you find. Vince
yes ^ that happened to me the snap ring wasnt in all the way and actually the boost valve fell out... i was on the lift, tryed to back off and i had no reverse......
Old 10-31-2010, 08:33 PM
Cook's Avatar
oh so something like this?
LOLOL snap ring must not have been in correctly. thanks again guys. especially vince.
Old 10-31-2010, 09:58 PM
Fastest D1 Procharged Truck
02_Orange_D1SC's Avatar
haha aleast you found the problem easy enough. btw your rear tires should move when the truck is up on the lift mine does but it wont move at all on the ground until you give it gas like stated cause of the 3600 stall.
Old 10-31-2010, 10:32 PM
FLT
FormerVendor
FLT's Avatar
Ding.Ding.Ding.Ding. I think we have a winner! Glad to help. Vince
Old 11-01-2010, 05:24 AM
Cook's Avatar
kurt- we backed the truck out of the garage but it kept stalling. we have a few codes on which hopefully can be corrected with a tune.
Old 11-01-2010, 05:25 AM
Cook's Avatar
thanks again vince
ARC
57
02-21-2022 10:54 AM
wrb002
08-31-2015 12:00 PM
Ketis
07-23-2015 12:37 PM
black6spdz
07-16-2015 01:32 AM
MileHighSierra
07-12-2015 12:23 AM
Quick Reply: truck wont go in reverse after trans-go HD2 install
