Truck will not start after trans swap....
Old Sep 12, 2008 | 01:29 AM
xlcooplx's Avatar
Default Truck will not start after trans swap....
I removed my FLT level 5 the other night to send back to be refreshed. I installed a factory trans/converter back into my truck tonight. Got everything hooked up and bumped the key, but the truck failed to start. Pulled the starter and tested it, it works fine. Battery also shows to be in fine condition. The small accessory wire on the starter doesn't seem to get power when the key is being turned, however, the large wire has constant voltage. Anyone have any idea what the culprit could be? I don't recall removing any grounds from the rear of the block. The only idea i have is the neutral safety switch, although i dont understand how it would go out from simply removing it...Any help is appreciated.
Old Sep 12, 2008 | 02:44 PM
006rcsb's Avatar
fuse?
Old Sep 12, 2008 | 02:51 PM
aarolar's Avatar
Check your neutral safety switch to make sure it's plugged in...
Old Sep 12, 2008 | 03:28 PM
trxmxzx's Avatar
13 Second Truck Club
i had this happen it was a fuse.... i bumped the starter shield and grounded everything out on the starter... it wouldnt even click.... check under the hood i think it was a 40 amp fuse... ill check the truck to see what one it was hope this helps
Old Sep 12, 2008 | 03:35 PM
trxmxzx's Avatar
it was my ignition fuse
Old Sep 12, 2008 | 10:28 PM
xlcooplx's Avatar
had the same thing happen. by any chance did it mess up your fuel gauge? My fuel gauge looks like this now.
I'm trying to find out which fuse is for the fuel sending unit.
Old Sep 12, 2008 | 10:35 PM
Manbearpig's Avatar
LOL I think your tank is full Matt
Old Sep 12, 2008 | 11:31 PM
00ChevyScott's Avatar
Wearin' da big hat
OMG ITS MANBEARPIG!
Old Sep 13, 2008 | 03:01 PM
trxmxzx's Avatar
nope I lucked out on that problem! does it even work? or is that when it shut off?
Old Sep 13, 2008 | 07:15 PM
xlcooplx's Avatar
randomly started working again today after i got off of work
ferrellrooster
Mar 6, 2025 03:22 PM
wrb002
Aug 31, 2015 12:00 PM
chevyl33
Aug 24, 2015 08:21 AM
cams 98 silverado
Jul 31, 2015 07:36 AM
black6spdz
Jul 16, 2015 01:32 AM
