Truck feels glued to the ground from a stop
Old Apr 14, 2008 | 09:41 AM
sprayed8's Avatar
Default Truck feels glued to the ground from a stop
so for a long time now (30k or so) every once in a while maybe once a week, when i leave from a stop light at normal speed there is some slight hesitation where it feels like something in the drivetrain is sticking. you can feel th engine load up, but the car wont move for like a second then it just lets go, as if it were the brakes. i'm not really sure how to pinpoint the problem, since i have gotten new rotors, pads ebrake shoes, tranny x2, and a new rear diff. since this problem has started. any ideas as to what it could be?
Old Apr 14, 2008 | 11:47 AM
thunder550's Avatar
High on diesel fumes
Interesting...mine has done the same thing a couple of times recently. Interested in hearing what it could be. Mine is a 4L80E, BTW.
Old Apr 14, 2008 | 12:56 PM
53RUSSELL's Avatar
I would check the caliber to see if they are sticking close. In my old cyclone under hard breaking the left side caliber would stick close for second and let go. Try replace or greece the slide pins or replacing. Also look at the shoes see if they wearing more on one side than the other.
Old Apr 14, 2008 | 01:26 PM
sharpshooter's Avatar
Grease the splines on your slip yoke.Mine has done this before also.
Old Apr 14, 2008 | 01:30 PM
sprayed8's Avatar
i'll defineately check that out soon, but when i had new brakes put on it still did it i just recently had it inspected at the shop i am good friends with and i think they would have let me know if there was some unusual wear pattern. i'm glad to hear that there is someone else with the same problem and i'm not just imagining this.
Old Apr 14, 2008 | 01:32 PM
sprayed8's Avatar
i will try greasing the splines hope its that simple. thanks for the input
Old Apr 14, 2008 | 01:50 PM
thunder550's Avatar
What causes that to happen?
Old Apr 14, 2008 | 07:17 PM
jhe2003's Avatar
I believe there is a Technical Bulletin that talks about this, it says that the truck starts off from second gear instead of first or something like that, I'll see if I can find it. Mine does this once every three months!!!
wrb002
Aug 31, 2015 12:00 PM
black6spdz
Jul 16, 2015 01:32 AM
06 4.8
Jul 15, 2015 07:17 PM
GreyChevy
Jul 7, 2015 08:57 PM
cwylie
Jul 7, 2015 11:42 AM
