Truck 4L60E vs F-Body 4L60E
Old Feb 21, 2008 | 07:56 PM
Dirty 30's Avatar
LS1Tech Whore
Exclamation Truck 4L60E vs F-Body 4L60E
Does a 4l60e from a 99-06 Silverado 2wd work on a 98-02 Camaro with an LS1? Does it just bolt up the same? Same length from the tailshaft to bell housing compared to F-body 4l60e? Obviously the trucks dont have a torque arm but we are using a short crossmember mount torque arm anyways.
Old Feb 21, 2008 | 08:29 PM
FLT's Avatar
FLT
FormerVendor
The units are very similar. The length is the same and it will bolt up. You will have to change the shifter linkage shaft and the second servo is different in the truck units. Might want to get yourself a corvette servo, linkage shaft, and you will be good to go.
Old Feb 22, 2008 | 04:48 PM
Dirty 30's Avatar
LS1Tech Whore
Cool, its cause Im looking for a stock 4l60e for a 01 camaro LS1 but i cant find any.
Old Feb 23, 2008 | 01:05 PM
jakebdb56's Avatar
One the tailshaft housing, do they use the same slip yoke? Comparing the housing from a '00ish Fbody 60E to the truck 60E the only difference I can find is the chassis mounts that are obviously different.
Thanks,
Jake
btw, dirty30 I have an fbody tailhousing if you need one. I won't be needing it for the swap in my truck, comes with a VSS as well
Old Feb 23, 2008 | 01:34 PM
Dirty 30's Avatar
LS1Tech Whore
Thanks, im hoping to just find a F-body 4l60e, if not, I'll let u know.
Old Feb 23, 2008 | 03:39 PM
jakebdb56's Avatar
Okey doke, I've got a Fbody 4L60E I used as a core for the internals, if you're looking for the center case I've got one just sittin in the garage. I went with a brand new 65E case for my build so I don't need it. As for the internals, I can't see any differences between the fbody and the truck so far. I did notice that the core I bought had a 13 vane pump in it lol
ferrellrooster
Mar 6, 2025 03:22 PM
Jakejack
Jan 8, 2024 10:44 PM
wrb002
Aug 31, 2015 12:00 PM
Ketis
Jul 23, 2015 12:37 PM
black6spdz
Jul 16, 2015 01:32 AM
