Trouble!!!! Need help asap!!!!
Old Apr 25, 2009 | 02:32 PM
  #21
02gmcbandit's Avatar
well if thats the prob i can get one for 120 "my special price" haha. and can get the tranny serviced for 90. what about the not wantin to shift and all? would that be because it basically didnt have fluid? my buddy said his tranny acted like that once and he put fluid in and it worked fine so would it be because the lack of fluid?
Old Apr 25, 2009 | 03:44 PM
  #22
SincalT/A's Avatar
Becareful to much fluid will kill that tranny real fast.If it close to the line say within an 1/8" do not add.
Old Apr 25, 2009 | 06:12 PM
  #23
viciousknid's Avatar
Where's the Beef?
1/4 mile at 120 is 7.5 seconds. I agree that the radiator couldn't handle the amount of pressure being pushed through it and broke something. I had that happen on a dyno once. The bottom driverside corner of my radiator blew out.
Yes. the slipping is because the pressure is bleeding off into the radiator and it doesn't have enough pressure left to shift or for the converter to engage.
Old Apr 26, 2009 | 12:08 AM
  #24
silver-mod-o's Avatar
Hunt&Fisherator
I'm pretty sure Vince said OVERHAULED not SERVICED LOL.... you need to go through that thing more than a flush and filter if you got coolant in it. I'd do it anyway at this point since youve had problems and possible contamination.
Old Apr 26, 2009 | 03:37 AM
  #25
well what would consist of a overhaul with a tranny? like stated im no tranny guy and am still learning how they work so any advice, tips, ect. is greatly appreciated
Old Apr 26, 2009 | 04:49 AM
  #26
Parke10's Avatar
basically tearing her down and rebuilding the internals of it
Old Apr 27, 2009 | 10:52 AM
  #27
well just ordered the new radiator, its supposed to be here tomorrow, next question, should i drain the tranny and put new fluid in before i take it to the tranny shop??? and if so what should i look for far as bad signs? and with the shift kit is there anything that will fall out? those lil *****, springs, ect.
Old Apr 30, 2009 | 04:14 PM
  #28
changed the radiator, and changed the tranny filter and fluid, no i didnt flush it but its not helped at all, its still not wantin to shift into 2nd and when it downshifts into 2nd it pegs the rev limiter and doesnt shift, WHAT exactly is wrong, meaning part, what needs replaced, please do not tell me i need a built tranny ect, i just wanna fix this problem and get it back running
Old Apr 30, 2009 | 04:52 PM
  #29
is this what i need? http://www.oregonperformancetransmis...ory_Code=4L60E
do i need nething else?
Old May 1, 2009 | 10:34 AM
  #30
getonit's Avatar
Dude if your going to be doing any racing you might as well get you a built tranny. Our sponsers build bad *** trannys. If you are going to fix the one you have carry it to a tranny shop you dont know what you are getting into. I sent you a private message.
