transmission shift issue under WOT after tire size change
Old 03-31-2013, 10:05 AM
03sierraslt's Avatar
Originally Posted by 2doorfury
Stall is 3600 and limiter is set at 6500. Tuner adjusted speedo for gears and tire size. Truck was fine before tire and wheel swap. And there is a minimal tire size difference which has Mr stumped. It shouldn't change it enough to mess with how it shift or acts up.
It shouldnt but it most certainly can, I would swap the wheels and find out for sure. Another good point mentioned above, what is your RPM drop when this happens around 60mph? Are you sure it is not the converter locking and unlocking? Transmission settings can be very picky depending on how close certain tables are to each other.
Old 03-31-2013, 10:13 AM
2doorfury's Avatar
About a 300-500 rpm drop. I'm guessing converter is unlocking..what reason would make it lock and unlock when it gets to a certain speed?
Old 03-31-2013, 10:17 AM
Speed and throttle position is what make it unlock, if your tire size is off in tune and the threasholds were already close then that can happen. Swap the tires and try it.
Old 03-31-2013, 11:49 AM
2doorfury's Avatar
Thanks guys! I'll go give it a try
Old 03-31-2013, 12:30 PM
11 Second Hall Moniter
AKlowriderZ71's Avatar
It's a tune adjustment. Unless your trans is slipping.
Old 03-31-2013, 01:04 PM
2doorfury's Avatar
Just got back from a drive. I left the 275/60/15 nitto 555's on. Did totally fine until the trans temp went up between 120-140. It feels like it gets stuck in 3rd. I can go from D to 3 and no difference. Then go from 3 to 2 and it'll go in second. but go back to D and it just whines out until I get to about 30, or when the gear catches up with the speed of the truck. If I shut the truck off and let it cool down, it'll go back to normal.
Old 03-31-2013, 04:25 PM
2doorfury's Avatar
Any ideas why it only does this when tranny warms up?? Its not even getting near operating temp really 140 is the most its got. I doubt it'll be drivable when a 80* days comes.
Old 03-31-2013, 04:26 PM
2doorfury's Avatar
Trans and converter are brand new with 1000 miles on them. Rpm stage 4 trans and a yank 3600 SST stall
Old 03-31-2013, 05:59 PM
PaulyC's Avatar
If you are heating your trans up past 160* on the regular theres something wrong. So by you saying it only got to 140 isnt good, that should be full operating temp. What speed and rpm are you going to when shifting from d to 3? if you really didnt have 4th the mil would be lit.
Old 03-31-2013, 07:20 PM
140 is not full operating temp...
Quick Reply: transmission shift issue under WOT after tire size change
