transmission shift issue under WOT after tire size change
It shouldnt but it most certainly can, I would swap the wheels and find out for sure. Another good point mentioned above, what is your RPM drop when this happens around 60mph? Are you sure it is not the converter locking and unlocking? Transmission settings can be very picky depending on how close certain tables are to each other.
Just got back from a drive. I left the 275/60/15 nitto 555's on. Did totally fine until the trans temp went up between 120-140. It feels like it gets stuck in 3rd. I can go from D to 3 and no difference. Then go from 3 to 2 and it'll go in second. but go back to D and it just whines out until I get to about 30, or when the gear catches up with the speed of the truck. If I shut the truck off and let it cool down, it'll go back to normal.
If you are heating your trans up past 160* on the regular theres something wrong. So by you saying it only got to 140 isnt good, that should be full operating temp. What speed and rpm are you going to when shifting from d to 3? if you really didnt have 4th the mil would be lit.
