transmission shift issue under WOT after tire size change
Went from factory size tire to 15 inch wheel with 295/65/15. Shift thru all gears fine cruising and at WOT. Did a WOT pull and never went into overdrive. Now when cruising, it'll go into ovedrive until about 60mph, then down shift. Under WOT, it won't go into overdrive. It'll go to 90mph and hit rev limiter..anyone have any ideas?? I didn't think tire size would effect how it shifts, just shift points.
I dont know what gears you have but you shouldn't be going into OD at Wideopen at 90mph anyway. Do you mean 3rd gear? Your above listed tire size works out to a 30.1", what was your factory size? Was the tune changed for the change in tire size? Tire size can change how it shifts, if you MPH limit is now not achieved then you can hit the rev limiter before the computer gets both inputs. The computer looks for both a RPM and MPH before commanding the shift, if it doesnt see both requirements based on what is set in the tune then it will not command a shift.
Not sure what your limiter is set at but there is a minimal difference between those two sizes, however it could be just enough to cause a issue depending on how the tune is set. I dont know how loose your stall is but here are some rough numbers for when it should be shifting.
39.8 1st
74.7 2nd
121.8 3rd
174.0 4th
All shifting at 6200rpm
This is why I am not sure what is up with having issues at 90, unless your speedometer and tire size already in the tune are not right.
39.8 1st
74.7 2nd
121.8 3rd
174.0 4th
Stall is 3600 and limiter is set at 6500. Tuner adjusted speedo for gears and tire size. Truck was fine before tire and wheel swap. And there is a minimal tire size difference which has Mr stumped. It shouldn't change it enough to mess with how it shift or acts up.
edit- saw your other post. if its only a few hundred the trans isnt shifting its the converter.
