Transmission Shift Cable question
Old Jul 6, 2014 | 08:13 AM
TIM Z's Avatar
11 sec. Truck Mod
Default Transmission Shift Cable question
I need some info on the trans shifter cable in my 2000 silverado ,
I was cutting an old bolt of my frame with a grinder/ cut off wheel , the grinder kicked back and put a good cut into my shift cable .
I searched and believe I need the part # 12477640 .
My question is , is my cable a two piece part ? Do I need the whole cable or just the part from the column to the " adjustment section " under the body near the frame ?
The cable that connects from the trans linkage to the " adjustment section" is fine , does it come apart there ?
If it's just as easy I can replace the whole cable I guess .
And where is the best place to get one ? Best I've found is about 78$ on amazon .
Old Jul 6, 2014 | 09:53 AM
thunder550's Avatar
High on diesel fumes
It does come apart at the adjustment part. You should be able to buy half. I got one for cheap at a scrap yard a couple years ago, can't remember what I paid though.
Old Jul 6, 2014 | 11:02 AM
TIM Z's Avatar
11 sec. Truck Mod
Thanks bud ! , I actually saw your post on that , helped me find out it was two pieces . I just need to get the part number for the half I need , unless it's easier to order and setup new cable .
Old Jul 6, 2014 | 11:20 AM
Gadgetized's Avatar
If you can get away with the portion under the truck, you will be much better off. The portion under the dash is sort of a pain to replace.
Old Jul 6, 2014 | 03:29 PM
TIM Z's Avatar
11 sec. Truck Mod
FML that's the piece I need , from under dash to the connection under the cab floor by the frame
Old Jul 6, 2014 | 05:16 PM
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
i bought mine at the local salvage yard and only did the section under the truck
Old Jul 6, 2014 | 06:37 PM
thunder550's Avatar
It's not that bad. Just cramped under there. You have to disconnect it from the shift lever, and I think there's a bracket it's attached to also. Then pull up the carpet and remove the grommet from the floor board.
Old Jul 6, 2014 | 08:59 PM
TIM Z's Avatar
11 sec. Truck Mod
Thanks , yup I already did all that , just waiting to check Monday to see if just half of the cable is available or if I need to buy the whole thing , what's left is in real nice shape
Old Jul 9, 2014 | 01:42 PM
Robert91RS's Avatar
#12477640 - it contains both halves because they changed the design some time back.
ferrellrooster
Mar 6, 2025 03:22 PM
LCHEE
Oct 24, 2020 04:10 PM
USMCvet0311
Aug 1, 2015 07:45 AM
lxcoupe
Jul 14, 2015 10:14 PM
