Transmission replacement on 94 1500
Old Nov 16, 2015 | 01:57 PM
jrod119's Avatar
Registered User
Default Transmission replacement on 94 1500
My current trans in my 94 1500 4.3 v6 has crapped out on me, and I'm looking to fix or replace. It currently has the 4L60, and after I get her up and moving again I'm looking to swap the engine as well. Most likely to the 5.3, or a 5.7. The current motor has 230k on it but still purrs, and other then my company vehicle which I drive majority of the time its my daily. However my main question is, and with taking into consideration the future motor change for this truck. Should I go with the same model 4L60 or should I go for something more beefy?
Old Nov 16, 2015 | 03:52 PM
1FastBrick's Avatar
Custm2500's Rude Friend
I believe the 94 is fairly specific to that application.
It will only interchange with 93-94 models.
Have it rebuilt, or replace it with a compatible model.
An LS engine has a different convertor offset and requires a newer transmission to run with the electronics.
Old Nov 16, 2015 | 04:09 PM
jrod119's Avatar
Registered User
I believe you are correct sir. With very little research I found that in 1996 chevy switched to a newer electronics inside the transmission. I guess I will look into having the one I have rebuilt more then replacing it.
Old Nov 16, 2015 | 04:18 PM
jrod119's Avatar
Registered User
Never mind on that I called 2 shops and both quoted between $800 and $1500 on a rebuild. Then I hopped on craigslist and found a rebuilt with warranty 93-94 specific 4L60E for $650
MOBBN
Sep 22, 2015 08:07 PM
ZxHybrid
Sep 18, 2015 04:44 PM
dselby25
Sep 11, 2015 05:03 AM
