transmission rebuilder
Old Aug 22, 2005 | 04:06 PM
OrlandoFL4.8's Avatar
Default transmission rebuilder
Im having a built up 4l60E installed in about 2 weeks from a builder out of Tampa (I dont know if I can mention them because they are not a sponsor) This tranny is advertised to handle 550 hp
The transmission includes:
reprogramming update kit
shift kit
raybestoes 9 clutches(replaces 5 clutches in the 3-4 drum)
9 clutch pack has specialized heat treated steels
all new reybestoes high temp energy clutches though out the rest of the unit
all new steels, bands, bushings, and ring
.500 bosst valve
10 vane pump rotor
4140 hardened pump rings
Teflon pump bushing
29 element sprag
sonnax wide open throttle valve
over sized hardended sun gear shell 3 times thicker than factory
hardened input shaft n drum
high temp pro series raybestos, kevlar bands
transmission cooler
Im also adding a high performance converter that will have a 2400 stall and there was something else they said to upgrade because I told them I would be running nitrous (he laughed when I told him I had been running nitrous for about a year on a stock truck) but cant remember what it was (price went up 300dollars). I wanted to run a 3200 stall because of future engine mods but they said with factory cam I would fry the tranny and to use a 2400 stall u ntill then?
The total price out the door pull and replace was $2000.00 does this sound resonable, are there any other questions I can aske them? they have been in business for 20years and have been great to deal with so far.
Thanks in advance
Old Aug 22, 2005 | 04:34 PM
That sounds like a good deal for that type of trans, the sun gear shell is weak link in most 4L60E I have seen. You might want to ask about corvette servo. Are the high temp plates the Blue Plate Specials? Most tranny shop don't replace the bushings except for the pump and tailshaft, I would ask about all the bushings. The most important thing to ask is how long is the warranty, I would spend that kind of money without at least a 1 year warranty.
Old Aug 22, 2005 | 06:39 PM
It is a one year warranty, I will be sure to ask them about the blue plate specials and bushings. What exactly does the corvette servo do, I have heard that mentioned a lot.
Old Aug 22, 2005 | 09:25 PM
99Silver6.0's Avatar
TransGo vaccum modulation kit!!!!!!! And make sure the guy uses full thickness kolene steels and a beast sunshell.
Old Aug 22, 2005 | 11:59 PM
The corvette servo puts more pressure on the 2-4 band, which reduces slippages.
Old Aug 23, 2005 | 08:28 AM
gonzo 6.2's Avatar
Your trans already has a 13 vain pump.You wouldnt want 10.I dont think you would want a pump bushing made of teflone
Old Aug 23, 2005 | 08:49 AM
1SlowHoe's Avatar
Destroyer of Transmissions
MAD DOG? HE is probaly talking about an anti balloon plate for your converter. I got my 65E from them.
Old Aug 23, 2005 | 06:42 PM
yes MAD DOG, and that is what I think he said, anti balloon plate. How has your tranny been running, how long have you had it?
Old Aug 23, 2005 | 06:44 PM
Ill ask him about that as well, and everything else you all have mentioned, I really appreciate the help from everyone here.
Thank You
Old Aug 23, 2005 | 11:04 PM
goshawk23's Avatar
Truck addict
you talk to most tranny builders and they will agree a 10 vain pump flows well enough and is stronger than a 13 vain. at least in my months of research this is what i have found.
03sierraslt
14
Oct 9, 2015 05:53 AM
gmcyukon
Oct 5, 2015 06:20 AM
jscherbs
Sep 30, 2015 07:54 AM
trevorh1
Sep 27, 2015 08:47 PM
sTNT971
Sep 26, 2015 06:27 AM
