Transmission problem, I think...
Old Feb 1, 2007 | 03:13 PM
Whippled2dr's Avatar
Default Transmission problem, I think...
When the truck is in park or neutral everything sounds fine. When I put it in any gear, a buzzing sort of sound like something is scraping on something occurs. When in drive or any other gear, if I start moving the less noticable (the quieter) the sound gets as I slowly increase in speed (like from 0mph to 10 mph). The second I stop the noise gets louder again. The tahoe has 126K miles on it and this trans has about 90k miles (on my 2nd 4L60E). The whipple has been on for about 25K miles. Beside the shift kit, servos and bigger cooler, the trans is stock. If the tranny is going out, I should start collecting for my 4L80E swap.
Old Feb 1, 2007 | 03:20 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Damn that sucks. How does the fluid look and smell?
Old Feb 1, 2007 | 03:34 PM
phasemaster1's Avatar
could it be your exhaust. when engine has a load causing it to vibrate? do you feel grinding ?
Old Feb 1, 2007 | 03:38 PM
Fluid looks clean and doesn't smell burnt.
I'll check out my exhaust, I did have an issue the other day with my exhaust and my hanger coming loose. Maybe something else is still loose.
Old Feb 1, 2007 | 07:36 PM
All exhaust is mounted on good. Its gotta be something in the tranny. Its sounds like its coming from the front of the trans. It drives fine and shifts fine so I dunno. I'm going to drain the trans tomorrow and check for any metal shavings. If it is the transmission I'm probably going to go with a level 5 FLT 4L65E. It also gives me a chance to throw in a higher stall torque converter.
Old Feb 1, 2007 | 07:45 PM
trever1t's Avatar
Archie, you always find the silver lining in the dark cloud!
Hey, you have 80 posts and we joined at the same time!
Old Feb 1, 2007 | 09:07 PM
I tend to read alot more than I post.
Old Feb 1, 2007 | 09:08 PM
you check that heat shield that bolts to your tranny next to cat?
Old Feb 1, 2007 | 10:36 PM
Nick™'s Avatar
torque converter may be on it's last leg??? that's just a guess....
Old Feb 2, 2007 | 12:37 AM
What does a torque converter sound like or feel like when it going south? Thats where the sound I think is coming from.
